Mike D
Does anyone know for sure that the Rami AV-532 is not capable of receiving the glide slope?
The documentation from rami only notes the VOR. Aircraft spruce mentions this is not for GS, but seems others think it can receive the GS.
So, is anyone actually using it for ILS approach and actually receiving the GS?
Background:
I have a Garmin GNS480 hooked to a GRT Sport. The antenna is a Rami AV-532 with the cable that came with the antenna for the run from the vertical stabilizer to the radio. (Looks like RG-58)
I can receive VOR and localizer but not the glide slope. I suspect it is the antenna, but can't be sure.
The other suspects are the ARINC signal has a loose wire, or user error.
Just learning about IFR and seems there is an issue with the equipment.
Background:
