I have had an aversion to taping joints and gaps for speed because I think of it as detracting from the beauty of the airplane and in cases where I have tried it there is a tendency for it to blow off at speed. However, I am getting to a short list of things I can do to further increase the speed.
I bought some gaffer's tape as suggested here some time ago and the minimum order was something like $100 so I have an adequate supply to experiment with. At Courtland, Alabama last Saturday I had a roll with me and some time to kill so I did a little work. I taped the joint between my nose wheel fairing and the sub fairing and I made a tape fillet on the out board side of the outboard aileron mounts. On one of the fillets I installed a span wise cover strip to reinforce the fillet attachment to the inboard side of the mount because the fillet wrap around seemed deficient.
My speed for the 125 mile race was 215.83 mph and there were hard turns in both directions. After the race I inspected the tape. The tape on the nose wheel fairing looked exactly like it did before the race. The overlay cross strip on the one aileron fillet was rolled back into a tight little knot but was still attached. The other fillet tape looked similar to the before race condition except the the inboard wraparound flap was not actually sticking to inboard surface of the aileron mount.
Yesterday when I went out to the hangar to restore some things like reinstalling the nav antenna elements I decided to take this taping thing a little further. I thought that closing the small gaps between the landing dear fairing elements might improve the speed a little so I did it. I haven't tested it so I have no semi-hard performance data (that's as good as it gets from me) but it looks like it should have less drag.
In the process I developed the beginning of some "feel" for the characteristics of this material and some primitive application techniques. I like the way it can be worked to conform to compound shapes during the application - it's not just a stiff tape that kinks when it is forced change direction slightly. From my aileron experiment I know that it will catch the wind and roll off if it is applied in an edge on cross wind direction. I have seen other tapes in use by fellows like Tom Moore that is narrower and more plastic looking so there are probably even better tapes in use.
I will use a 182 kt reference speed to judge if the taped fairing joints provide any improvement in speed. In the mean time I would be interested to hear from anyone on their actual race taping experience.
Bob Axsom
Bob Axsom
