I want to install one of these but the applications shown on Spruce's site (https://www.aircraftspruce.com/catalog/eppages/safOilDrainValves_07-00879.php?clickkey=92892) do not indicate this is applicable for the IO390.
If it works on the IO360, will it work on my IO390?
It should, see the parts catalog for the IO-390-C
https://www.lycoming.com/sites/default/files/IO-390-C Parts Catalog PC-IO-390-C.pdf
Pages 38 & 39, drain plug is listed as a 1/2-14 NPT (STD-551 PLUG, 1/2-14 NPT, square head, drilled)
A lot of us use them on the IO-390, works great, mine is installed forward left drain port.
