T tjo Well Known Member Oct 3, 2014 #1 It looks like I will be buying a quick build wing from someone this weekend. Does anyone have recommendations on what to look for? Tim
Mike S Senior Curmudgeon Oct 3, 2014 #2 Are all the parts there?? What work has the seller done beyond the factory quick build? Plans/instructions. Hardware/fittings/weldments. Good luck with the purchase.
H Harvey L. Sorensen Well Known Member Oct 20, 2014 #3 wing kit I thought that the wing spars were matched to the center section, the spar bolt holes and center section holes were drilled together at the factory. I may have been miss informed. Harvey L. flying 9A flying 12 flying J4 CUB
