In working on the vertical stabilizer, I have found that the rear spar doubler (VS-808PP) has come out of the crate with a significant bend in it. Since this piece is 1/8" thick, I'm guessing that the aluminum comes to Vans in a large roll rather than a sheet and the bend is left over from the aluminum supplyer''s manufacturing process.
When this piece is cleco'd to the actual rear spar, the assembly ends up with roughly a 1/4" bend in it, which is unacceptable.
My thought is that this is probably so common that I haven't been able to find anything about it on the forum. I'm of the opinion that some of the stress needs to be relieved to allow the actual spar to keep the assembly straight.
My questions are:
1) Is this as common as I think it is?
2) If so, what method did you use to take out the stress/bend?
3) I'm of the opinion that the doubler doesn't need to be perfectly straight, it just needs to have enough of the stress removed to allow the actual spar (VS-803PP) to keep the assembly perfectly straight, is this correct?
Pictures are below.
Fred
My questions are:
Pictures are below.
![VS-808PP%20Bent.jpg](/community/proxy.php?image=http%3A%2F%2Fi743.photobucket.com%2Falbums%2Fxx77%2FDogdewd%2FVS-808PP%2520Bent.jpg&hash=134f9a179bc13380d3abfc02f96fa8a7)
![VS-808PP%20Bent%201.jpg](/community/proxy.php?image=http%3A%2F%2Fi743.photobucket.com%2Falbums%2Fxx77%2FDogdewd%2FVS-808PP%2520Bent%25201.jpg&hash=f8b26b29b98907a4b7abc1b5b58fc220)
Fred
