I'm working on the forward fuslage and getting the angle in place that is behind the 796a bracket that attaches to the fuel tank. the directions have you leave the holes at 1/8 but then when you go to attach the bracket and fit it to the wings you will have to drill this hole out to 3/16 and then use the bracket as a guide to drill the second hole. It looks to me that it would be better to drill both holes before the wing is in the way and you will need to use an angle drill? what do you people that are past this think?
