rv9aviator
I am still fighting a heat problem with the exhaust pipes being too close to the cowl and scorching the fiberglass. The rubber hose exhaust hangers just won't keep the pipes away from the cowl The mufflers are very close to the cowl bottom as well. I am going to change the hangers to attach to the sump and add a cross brace but after looking the situation over I am thinking I also have an exit air problem. The mufflers themselves block a lot of air going to the lower cowl exit area as compared to just exhaust pipes. I am thinking about reshaping the bottom of the cowl to widen the exit area some which will do two things. It will increase the exit air area and give the mufflers and pipes more clearance. I am talking about maybe an inch on each side. I doubt it will increase the exit area much over the original design but will account for the blockage of the mufflers. Any thoughts or advice? I'll post a picture tomorrow looking up into the bottom of the cowl.
