BuckWynd
Does anyone know if Van's lighting dimmers have an "Off" detent, or just a minimum-brightness position?
Thanks!
Thanks!
Don't have one so not sure, but from the pic below there are only two wires off the Pot (potentiometer), which means there is likely no ON/OFF switch (detent). If there was a switch there would be two more wires from the Pot for the switch. You can buy Pot's with SPST switches piggy backed off the Pot from a local electronic supply house, Mouser or Digi-Key.Does anyone know if Van's lighting dimmers have an "Off" detent, or just a minimum-brightness position?
Thanks!
Will these dimmers work on the ground side or only the power side?
They are a voltage regulator to provide a (variable) lower voltage to the lights. So, power side.
PJ Seipel
RV-10 #40032
