Ralgh
Member
I am up to the point where it says to put a slight break on the trailing edge of the elevator skins. I have the hand tool you run across the edge (I forget the proper name) to do that but it will put the bend right at the edge of the rivet hole. Is it okay to have the bend right there or does there need to be a little separation? I didn't have that tool yet when I did the rudder so I used a had seamer but it didn't come out as nice and uniform as my tool with the rollers does. Thanks for the help.
