I am getting ready to cut the holes in F-972 (bottom, forward fuse skin) to accept the WD-921-PC (L&R) landing gear mounts. Per the template on Dwg 34A, it looks like the hole I need to cut will require me to cut into the flange of F-904A (center section forward bulkhead), very near the rivet line where F-904A is riveted to the bottom skin. Am I looking at this correctly? I want to make sure before I cut!
Thanks.
Thanks.
