So far, my 9A QB kit has been flawless. But today, I think I may have found a mistake that the assemblers made, but I want to summon the advice of others before jumping to that conclusion.
When fitting F-983A (fuel valve cover), per the F-983A ATTACH DETAIL on Dwg 34A, it says "DO NOT RIVET THRU F-904A", which is the center section forward bulkhead. But the two inboard-most holes in the top of F-904A already have nutplates installed in them (from the factory), when I believe they should be installed on the fuel valve cover instead. Has anyone else run into this? I would like to know before I drill them out (from the bulkhead) and continue on.
Thanks for any input.
Greg
Greg
