My search results didn't discuss why someone chose a certain oxygen system over another. So for those of you who installed a built-in oxygen, which system did you choose and why?
Also, lot's of information about mounting the bottle, but very little about mounting the outlets. Anyone have pictures of those locations?
I've only been looking at the Mountain High systems (less chance for analysis paralysis) and there are basically three styles.
(1) - the 4ip which is a full-up built in system that uses pulse technology to save O2, has a nice instrument to mount on the panel, but is the most expensive.
(2) - the O2D2 which also uses pulse technology, is portable system which can be semi-permanently mounted. It costs less, but isn't as easy to use since you have to access the button on the control box to operate it.
(3) - the A34 which is a continuous flow system that can be used with their oxygen saving oxymizer cannulas. It uses more oxygen that the others, but costs less and is a proven older technology.
While it's tempting to go with the 4ip and all of its bells and whistles...I'm not sure that a simple and inexpensive system wouldn't do just fine. What I wouldn't want to happen would to be on a multi-day (or week) trip and run out of oxygen in the bottle with no way to refill it...which is where the 4ip would do well since it has good gas(oxygen) mileage.
So, I'm looking for opinions from the field.
Thanks in advance!
-Jim
Thanks in advance!
-Jim
