I am replacing my pitot tube (Dynon heated AOA pitot tube). I wondered if I could avoid flaring the new aluminum tubes (at the aluminum to plastic ends) by using a push on connectors, like those use "downstream" where plastic meets plastic. Extensive searching found nothing specifically for aluminum tubing. Am I overlooking a straight connector that accepts aluminum and plastic, one at each end?
