Hello..first post for this noob. Although I always thought I would build, I am currently looking at a built RV6A that presents some logistical problems.
When I describe this, some here will probably recognize the owner/plane.. I know he has posted here in the past. It's a 2003 6A, looks real nice, well built, and when I searched on the N number I found the guy's builder's website with detailed pics of the plane under construction. Also turns out the builder is an A&P and has been giving RV builders workshops. So far so good!.. until I notice that there's come significant differences with the plane after it was built as opposed to the current pictures in the ad.
Yep.. turns out there was an incident - hard landing, then nose gear collapse taxing in resulting in a tip over. The new engine was torn down as per insurance with nothing found. The plane was repaired - the tip up canopy was converted to a slider in the process and a complete 7A empannage was used. It was repainted, and a new (nicer) panel configuration was put in. The plane has not flown since last summer because the owner's medical expired and he wants to retire and move south. He says he's been starting the engine fairly regularly every since. The plane has under 100 hours, including pre and post accident. Now conventional wisdom might say to turn in the other direction and run, but for the fact that it might be a very well built RV.. maybe better than I'm likely to find elsewhere.
First question... this sounds like a 'major' incident to me and TAP's evaluator says to discount about 10K. Sound reasonable? The other thing is it's not insured now and the owner is not current... any advice as to how to get over this hurdle? I have no time in RV's and have contacted a few of the recommended transitional training guys.
Sorry for the long post... any wisdom appreciated.
Kerry M
Kerry M
