harrisonaero
Member
Hey Guys,
I’m fairly new to the VAF forums so please take it easy on me
I’m looking at taking the plunge into becoming an RV owner and figured I would ask a few questions here first to help me better define my mission before I purchase something.
I’m wanting a XC focused plane for working. Most of my travel will be to west coast airports and it makes sense to use a plane when the weather permits.
Seems like with the ailing economy and growing RV fleet there are quite a few choices of used RVs so I would like to purchase something that has as many top-notch features as possible without having to retrofit. Over the years, probably like many of you, I’ve learned that it’s usually cheaper to wait and find something that has what I want rather than trying to modify something afterward.
Here’s a list of what I’m coming up with so far:
Primary (required)
side-by-side, two-place
trigear
200+ mph cruise
IFR
autopilot
very accurate and reliable engine monitoring (individual cylinder CHT/EGT) for running LOP
reliable and proven systems (nothing new and novel)
all airframe/prop/engine ADs/SBs complied with including nose-gear leg/fork upgrade (if applicable)
Secondary (desired)
under $60k
light (bare aluminum and a sparse interior is OK)
simple/light panel
aircraft-grade (mil-spec) wiring
wiring ala Aeroelectric Connection philosophy (fault-tolerant)
one mag, one electronic-ignition
TBI or direct-injection
clean/efficient cooling and intake
drag mods for fuel efficiency
CS prop for high altitude performance
two-place oxygen
custom/tight-fitting canopy cover
Can anyone give me some tips on some of the preferred (most reliable and/or the best performing) components to achieve these goals? Such as… “If you’re gonna buy a plane with an autopilot then ya gotta get JoeBob’s-Wonder-Wing-Wobbler if you want it to last.” Or, “If ya wanna go 200 mph ya really need to be looking for a plane with these speed mods…”
Thanks folks and I look forward to joining the RV community![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Joa
Primary (required)
trigear
IFR
autopilot
Secondary (desired)
under $60k
simple/light panel
two-place oxygen
Joa
