BuckWynd
Has anyone out there figured out a way to mount a Push-To-Talk (PTT) pushbutton in the end of their throttle grip? (I'm using a CT-83F Deluxe 3-lever quadrant -- this is the quadrant that Van's sells, often used in tandem RVs).
After decades of flying airplanes with throttle-mounted PTTs, I'd like to be able to replicate this feature in my RV-8, but there does not appear to be any way to run the wire(s) from a switch down the shaft of the throttle lever, since the shaft goes through a very narrow slot in the base. I briefly thought about running a coiled wire across the space to the cockpit sidewall, but that idea was eliminated for several reasons (reliability concerns, mainly).
Anyone using a commerically-available throttle quadrant that would allow a PTT in the end of the throttle grip? Thanks in advance.
