llavalle
I'm just about ready to start sealing my first tank on my -9A.
The instructions say that the only piece that should be primed is the attach angle that goes in the inboard leading edge : that had me thinking. If this is primed, the pro-seal will not stick.
1)Then I thought : do I need to seal the outside of the outboard ribs? I don't see any reasons to do that... The inside filet will prevent fuel from getting under the ribs. For the inside ribs, I get it : you do not want fuel getting in the rivet's hole and dripping out.
2)Same question for the AD6 rivet I just drove in the tooling hole : covering the inside should be enough?
3)While I'm at it, when I'll back rivet the stiffners in the tank, I won't cover the rivets with pro-seal. I'll put a nice layer on the stiffner, install and back rivet, make a nice filet and cover the rivet's head. For the ribs, do I need to add pro-seal to the rivet's before driving it?
Tomorrow (well, later today, it's 2 AM here
) will be my first sealing session with pro-seal and I want to get it right. I've only used it when I closed up the trailing edge of my empennage parts a couple of weeks ago.
Thanks!
Thanks!
