Tom, I sealed my tanks during the summer and the Houston area heat and humidity were a force to be reckoned with. I mixed small batches, enough to do one rib at a time. The working time will be reduced but its manageable. In the end, pressure check resulted in no leaks. Hope you have similar results.
