Noah
Planning a Hartzell CS Blended Airfoil Prop. Vans publishes two numbers (both for CS prop) regarding the correct thickness of a "prop simulator" for positioning and fitting the cowl. In the manual, they say build a spacer 2-1/4" long. In their "supplemental instructions" on their website titled "Simulating the Propeller for Fitting the Cowl" they say to make spacers 2-1/8" long (Both of these are for CS props). Which is correct?
Page 12-2 of the construction manual for the RV-7 (bottom of the page) says: "If the (CS) prop is not available, a spacer 2 1/4" thick, attached to the front of the crankshaft (be sure the starter ring gear is installed!) may be used to simulate it."
Here is Vans "Supplemental Instruction":
http://www.vansaircraft.com/pdf/Prop_Cowl.pdf
I called Vans and they were not concerned by this inconsistency in dimensions and said that there is significant variation between props and recommended buying a prop to get the right spacing. (Great answer guys
, why publish the option to use spacers if you don't recommend their use). I cannot believe that there is that much variation in thickness of CS prop hubs, but what do I know? I would expect that a type certified prop hub (which this is) would have thickness variation of +/- .005 to .010".
I don't really want to incur the expense right now, but more importantly, I don't want to wait 1 or 2 months (per Vans this AM) while I wait for my prop to arrive to get to work on fitting the cowl.
So, can anybody else who has installed a Hartzell BA prop recently and used a prop simulator weigh in on what is correct here??
