I'm building an RV-7 with a O-360 Lycoming and rear mounted prop governor. The governor I have is a Woodward H210681. I ordered Vans governor/cable bracket for a Woodward governor. I sent the governor to a governor repair shop for cleaning and bench test. The shop owner is telling me I have to spend another $500 for a special part on the governor to fit a special bracket to make it work.
This doesn't sound right to me. Is anyone else using this combination? Have a picture of the install?
Thank you
Thank you
