BruceMe
I'm converting my O-320-B2C hollow crank engine to CS. I had the shop do the crank side, but the flange has the wrong bushings.
The hub is a Hartzell HC-C2YL-1BF. "L" style flange.
I found the threads on Lycoming SI1098N. I "think" it has these on it now... (I'll pull one and mic later today)
72066-S
72067-S
72067-S
72067-S
72067-S
72067-S
I believe the C2YL hub wants...
72065-S
72063-S
72064-S
72063-S
72063-S
72064-S
If anyone out there has done this, I could use a cross check.
And where can I get them for something less than $200 a lug !?!?
Thanks!
I have the same prop HC-C2YL-1BF/F7663-4 and I just had it o-hauled and zero timed. here is what the manual calls for
Stud A-2247-1
Bolt N/A
Nut A-2498
Washer/Spacer A-2482
Spring Pin B-3842-0625
O-Ring C-3317-228
Torque Nut/stud to 45-55 ftlbs
The studs/nuts/pins are about $600.00 for six of each. they came with the o-haul kit
As for the bushing/flange they do not mention them in the book
[/url]IMG_0008 by crouch.timothy, on Flickr[/IMG]
Prop Drive Bushings
Call Bob at Aircraft Specialty Services in Tulsa (918-836-6872) and buy serviceable used ones. He will know what you need.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
BUSHINGS
Call the shop and we should be able to come up with a set.
Jesse
970-874-7575
prop flange bushings
The part number bushings that you call out are for a crankshaft with the .27" flange thickness. If your flange is .38" thick, PMA part #'s are available from Continental Motors ( though Aviall )
AEL18817 ( 1 ea. )
AEL18315 ( 3 ea. )
AEL18816 ( 2 ea. )
Kind Regards,
James ( J.B.) Ball
Continental Motors Inc.
[email protected]
Measurements
My flange is .27"
The bushings are all 3/8" thread
A Bushing - A=0.66" B=1.02" 72066-S
B-F Bushing - A=0.62" B=1.02" 72067-S
I'm pretty confident I need this bushing set;
A - 72065-S A=0.67 B=0.90
B,D,E - 72063-S A=0.62 B=0.90
C,F - 72064-S A=0.62 B=0.48
I tried calling airparts 4x, but Bob was perpetually busy. I'll try others
I believe I have a full set of these for a 320, I'd have to look in my parts bin.. PM me
