jacksel
Noticed the lower sleeve at at the end of the prop control cable has separated where it joins the fixed part and there is several inches of exposed cable. I tried to insert an image but couldn't figure out "insert URL for image" message.
Can anyone help me?
John Walsh
RV-6 2005 922 hours
I had the same problem. I disconnected the cable from the governor and slide a short piece of black reinforced fuel line type tubing over the end and then used two small SS hose clamps to hold the pieces together. Works fine.
