rvanstory
Recently had to replace a cylinder (#1) on my IO-540. Since engine was "balanced" during assembly by Aerosport Power, decided to replace the cylinder but NOT the piston (piston was fine) to maintain measured piston balance.
Upon 1st breakin flight of new cylinder, the engine did not seem as smooth as before. Can replacing a cylinder (but not piston) affect the balance? I just assumed that since the piston stayed the same, things would still be balanced, but now not sure. Any insights from others would be appreciated.
