Hi All Seasons Greetings
Santa deliverd my loverly new metal prop and i was just tinkering this afternoon and noted that the Dowl Pins on the Spacer are a very tight fit into the prop so much so with the spinner back plate between them it would take a good mallet blow to get them together and i don`t know how you would seperate them .Is this right or should they be a nice slide fit and if so has any one else had this problem.
Mark
Mark
