Question:
Is the recurring Hartzell AD a necessary task if running an experimental engine? I'm sorry if this has been kicked around already; I just didn't see it.
Thanks, Lorne
I found this, dated 3/12:
http://www.faa.gov/documentlibrary/media/advisory_circular/ac 39-7d.pdf
9. APPLICABILITY OF ADs. Each AD contains an applicability statement specifying the product (aircraft, aircraft engine, propeller, or appliance) to which it applies. Unless stated otherwise (see subparagraph 9b of this AC), ADs only apply to type-certificated (TC) aircraft, including ADs issued for an engine, propeller, and appliance.
b. Non-TC?d Aircraft and Products Installed Thereon. Non-TC?d aircraft
(e.g., amateur-built aircraft, experimental exhibition) are aircraft for which the FAA has not issued a TC under part 21. The AD applicability statement will identify if the AD applies to non-TC?d aircraft or engines, propellers, and appliances installed thereon. The following are examples of applicability statements for ADs related to non-TC?d aircraft:
(1) ?This AD applies to Honeywell International Inc. Auxiliary Power Unit (APU)
models GTCP36-150(R) and GTCP36-150(RR). These APUs are installed on, but not limited to, Fokker Services B.V. Model F.28 Mark 0100 and F.28 Mark 0070 airplanes, and Mustang Aeronautics, Inc. Model Mustang II experimental airplanes. This AD applies to any aircraft with the listed APU models installed.?
This statement makes the AD applicable to the listed auxiliary power unit (APU) models installed on TC?d aircraft, as well as non-TC?d aircraft.
(2) ?This AD applies to Lycoming Engines Models AEIO-360-A1A and IO-360-A1A. This AD applies to any aircraft with the listed engine models installed.?
This statement makes the AD applicable to the listed engine models installed on TC?d and non-TC?d aircraft.
So, it looks like it all depends on how the AD was written.
