Ingo Weise
Active Member
I've got a question for those of you, using a Sioux air drill.
I recieved my air drill from Avery, and when I tried it the fist time, some grease came out of the front bearing.
Either the drill or the chuck (with key) seems to be out of balance. The tip of any drillbit I tried moves around about a millimeter (0.04 inches), but works fine in my electric drill. Has anyone of you had a problem with the Sioux drill?
I have another Problem with my full swivel air regulator, that I want to use with my rivet gun. When I move the gun around, the is some air leaking out of the swivel connection at the threaded portion that goes into the rivet gun.
Thank You.
Thank You.
