BOORSMA
Member
My Garmin GTR-200 display will sometimes go fuzzy such that the settings can not be read. By just putting a little pressure on the display with my finger it clears up. But, then shortly afterwards, goes fuzzy again. As far as transmitting and receiving everything works fine.
Has anyone else had this problem?
Dave, just call Garmin. I had a similar problem with my GTR200. They replaced my radio even though it was technically out of warranty. Said the company gives the support team some latitude with builders since the units are often not installed right away. In my case there was a software/firmware problem in a certain Serial # range that required replacement vs. update. Good Luck! Hope you receive the same friendly and prompt support that I did.
Dave.
