Steve Gavitt
Member
Hi I installed my fuel gauges as per VANs and during the calibration process (Dynon) everything seemed fine ? indicators work. However upon taxing out I noticed that the left indicator showed a lower amount than previously indicated and a minute later showed 0 fuel. I thought it was the wires but everything seemed to check out okay. When I tested the gauge on the plane I was not getting any connection (Ohms should have been between about 270 and 30). So I figured it was a bad gauge and ordered a new one. Got the new one and tested it both on the bench with the multi-tester and prior to installing in the tank with the Dynon hooked up ? everything okay. Installed the guage and added fuel ? indicator seemed to work okay. However again when taxiing out the indicator went to 0. Tested the gauge and got no connection. What gives? Anybody have this problem? Thanks, Steve.
