papamike
Hi,
I'm about ready for inspection and first flight.
I have a flop tube in the right tank, so the float got moved to the second tank bay out. I'm trying to fill the tank and calibrate using Skyview. The left tank went great.
Basically, the right tank is not getting any changing readings up to full. There is a very slight change about midway through (10-12 gallons), but even nothing different after that. I am getting readings, so I don't believe wiring is an issue.
I went through the entire process regardless. Dynon asked if I wanted to keep the settings, and I said yes. But the right tank still shows the Cal prompt.
Any ideas before I pull the tank?
I'm even thinking about taking the flop tube out and putting it all back the way it is on the left side...
