Airparkguy
I'm New Here
Hello forum,
Since my last post I have got my servo working thanks to some of the members here. It turned out to be a worn out feedback pot. Noe the only problem I see is the gyro apparently when it goes from level to any turn and back to level there are 2 light springs on the gyro motor assembly and the gyro bounce back and fourth from level til it settles down then it is ok. I wonder if heavier springs would bring it back without that problem? Has anybody had that problem? And change spring tension? It is not a servo problem as you can see and hear the gyro bouncing and the servo just follows what the gyro is doing.
Thanks again for your help.
Regards
Earl
N903EP
