After 7 years of flying with erratic fuel flow display, I decided I would change my originally placed transducer to a better location instead of before mechanical pump to after same pump. I now have stable indication for fuel flow but now it is reading much higher at cruise rpm and at idle. For example at idle of 600 rpm I'm reading about 5.5 gph. No way, I should be reading more like 1.5-2 gph.
Here's what I did differently, put transducer on top of engine just before fi spider with a 3" fuel line, inlet side has a 45 deg elbow to connect fuel line from baffling . I'm just wondering if the elbow could be causing some kind of turbulence or some odd reaction. My previous location had straight fittings with longer in and out straight fuel lines. Any ideas?
Dave Ford
Cadillac , mi
rv6 flying rv10 building
Dave Ford
Cadillac , mi
