I am ready to prime some parts of my 10 empennage to prevent corrosion. I plan to use a rattle can with self etching primer. However there are a number of parts which are smaller and would be difficult to hold as I spray them. I watched Brian Carpenter on an EAA tip for homebuilders demonstrate the Alodyne process with acid etching. This appears to be an easy process for these smaller parts. 1) will this work sufficiently to protect against corrosion on those parts that are difficult to spray 2) will the fact that some of the parts still have Alclad and other parts have been sanded free of Alclad due to deburring attempts affect the Alodyne process? Thank you.
