wirejock
I've mentioned it before. If I ever build another, the interior paint will be primer. No primer and top coat. Just a 2K Epoxy primer. Several brands are available in colors. EnduroPrime is white, gray and black. Mix a neutral shade if you like. Other brands probably have options as well.
I had an interior part get paint damage under the bench. Today I was spraying fiberglass parts with primer. Flat black is flat black so I sprayed the part.
A quart of Jet Flex costs more than a gallon of EnduroPrime and it's no where near as tough. Heck a pint of Jet Flex catalyst costs more than a gallon of EnduroPrime catalyst too. Don't get me started on shelf life.
Here is a photo. Can you tell which one is Kirker EnduroPrime and which is Jet Flex?
![20221020_164603.jpg 20221020_164603.jpg](https://vansairforce.net/data/attachments/19/19416-580f377205262c7b2f82434d83867289.jpg)
