Finishing up a 30 year RV4 project I took over. It was Vari Primed over a decade ago and I have sanded the Vari Prime and have put down an initial layer of acrylic urethane primer. I intended to assembly and fly the aircraft before finish painting. I had a space I could use for a brief period to prime, but it was unheated and sprayed at the low end of acceptable temp. A few runs, and some areas it did not lay down real smooth.
Would it be best to leave the surface untouched until ready to final paint, or is it OK to smooth it out a bit with sand with 400 to 600 grit paper?
Should I do anything to protect the primer, so type of coating?
