rjm727
I mounted the battery box without priming the mating surfaces and I am now wondering if I need to remove it and prime them? Also, there is no callout to prime the vent boxes where they attach (nor does it say to proseal them).
I know there is less hand-holding at this point but more consistency in the directions would be helpful in reducing the “pondering” time…maybe that is calculated into the 51% rule ;-)
Do I need to remove the batt box and prime the mating surfaces??? I have painstakingly AKZO primed the whole airplane but I don’t like the idea of something in front of the firewall that can “soften” with heat and put out fumes. Thoughts?
