M mquam99 Well Known Member Feb 19, 2012 #1 I have two pressure senders for an EIS-4000 that I purchased second hand. Can anyone tell me which of these is the oil sender and which is the fuel pressure sender?? thanks
R Rupester Well Known Member Feb 19, 2012 #2 Fuel pressure (like, 0-30 psi range) is the two-wire sender. Oil pressure (like 25 to 100psi or somesuch) is the one wire sender. BTW, even when you buy them new from GRT, they're not labeled as to which is which.
mannanj Well Known Member Feb 19, 2012 #3 Guages If I remember correctly; they may be embossed in bars (14.7psi = 1 bar). ie: 0-9 bar, 0-5 bar, etc. It's been a long time, so I could be wrong.
M mquam99 Well Known Member Feb 20, 2012 #4 thanks both of you were right on.. the two wire is fuel and labeled 0-2 BAR and the one wire is oil and labeled 0-10 BAR.. thanks as always
