RV7AJeremy
I got a new engine and I had an A&P pickle it. The cylinders are filled with oil, and the oil is leaking out the bottom spark plug holes. The holes are plugged with a red plastic plug but it is leaking (not surprisingly) Is there a better way to plug these holes so that the oil does not leak out? I would rather NOT use my new spark plugs. Thanks in advance!
