flickroll
I've decided to use the ClickBond nutplates for securing my -8's batwing wing tips. The ClickBond nutplate is bonded to the inside of the tip using ClickBond's epoxy adhesive. What is the best method for prepping a surface such as this for a bonding operation? Is there a mold release here that needs to be removed, and if so, how? Or will simply scuffing it up by sanding it with an 80 grit paper, followed by a wipe down with alcohol suffice? Thanks
