Hello,
I've just started building a Van's RV-7 down here in Sydney, Australia.
I've been researching primer solutions and I've made my mind up to use Prekote as the surface pre-treatment.
My question: Once Prekote has been applied as per the application instructions I was thinking of using a Zinc Oxide 'rattle can' primer - such as that made by 'Tempo'.
Does anyone know if that is a compatible primer or is there something else in particular that is recommended? This will be for all internal steel and aluminum parts. Given I'm building my aeroplane in my garage (attached to the house) I'm looking for the safest possible solution but with good corrosion protection.
Best regards,
Simon Williams
Sydney, Australia
(working on RV-7 emp).
Best regards,
Simon Williams
Sydney, Australia
