frankh
Well its that time of year when the first frost up here in Western Oregon has been predicted. I seem to remember from my engine manual that preheating is required below 40F.
I view this as another money saving opportunity. This is typical of engineers, not that we're cheap per se'e, just that every challenge is an opportunity to optimise the feature set and minimise cash outlay all it once.
Anyway, I have my propane shope heater that is the 6 to 8" tube with a propellor fan in the back and a burner.
The obvious solution is to get some ducting and hook the tube directly to the cowl inlets (or outlets) and fire it up...Minimal cash and resuses and existing tool...Cool...Downside is that this is a naked flame.... so not ideal but still difficult to ignite something as the airflow is pushed away from the heater. The other potential problem is that propellor fans do not usually make much pressure, so adding a resistance like duct work and the engine cooling systems which is a high pressure loss (at high speed anyway) may make the heater run ROP..
..Or not at all. I note that proper preheat machines use a backward curved centrifugal fan...These make much more pressure at low flow.
The other idea is to use a $150 tent heater...This is an indirect heater with flex dryer ducts...You could even carry it with you for Winter camping trips as long as you don't mind propane cylinders on board. This also has a prop fan I believe but the flow rate would be pretty small as its only ay 4" fan...Thus flowrate is low and the pressure drop thru the engine drops off with the square of the flowrate...So it might work.
Anybody tried either of these ideas and lived to tell us about it?
Frank
Frank
