Hello RV Builders,
i had fallowing trouble today.. i had a first Engine Start Today, and i checked during the first secunds my Throttle Direction (Open-Close) is in the Wrong Direction!!!
Whn i open the Throttle in the Cockpit the Lever on the Injector Servo goes in the Idle Position, and when i close the Trottle in the Panel the Servo (Lever) goes to full open (high RPM) !!
That was not realy funny during the first time running!!!
Question: Is it possible to Change one my current Injector Servo the Lever or other things so i can becom the correct wa from the Lever, or is a Injector Servo avialable with an "reverse" Open/Close Lever ??
I had not the exact Part Number from my current FI in Hand, but its an Precision RSA 5.... Injector Servo on a IO320 Lyc.
Thanks for Help
Manfred
Thanks for Help
Manfred
