which way do you turn the idle mixture screw to ritchen or lean a precision carb.
It's a needle valve, so it works just like any other typical valve.
Unscrew (counterclockwise) to open / make richer.
Screw in (clockwise) to close / make leaner.
Make sure you maintain compression on the spring between the head of the needle valve and the carb. It is the only thing that keeps the needle valve from vibrating out.
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
