Heat treated rivets
Rivets, where do I start, there is a myriad of materials and types of application for rivets, way too much to go into here, discussion about AD rivets on the VAF are just scratching the surface of the rivet world. I've been working on large airliner aircraft for 21 yrs and I'm still learning about rivets.
I'm reading this thread and wondering why you would want to or even need to heat treat or as stated soften AD rivets.
AD rivets are easy to put down, so really there isn't a need to heat treat them. A very real consequence is that you will end up with a load of annealed rivets in your aircraft that don't age harden like properly heat treated DD rivets, instead you have an aircraft constructed with soft annealed rivets, not a good situation.
Heat treating any form of alloy either rivets of formed parts should be done under strict conditions by trained operators with the proper testing equipment to ensure the process has been carried out correctly. The most common alloy used in aircraft is 2024 T3, this also comes in annealed (soft) form designated as 2024 O, this material is used to fabricate parts from, usually complex angles or Z sections, then they are re annealed to remove any induced stress then heat treated to a exact temp for a specified time depending on thickness, then water quenched to set the grain and finalise the heat treating process, other alloys can be heat treated, 7075 T6, the list goes on and on.
If you know someone who is an aircraft engineer, aircraft sheet metal worker who works for a large repair organization specialising in big transport aircraft, ask them to fill you in on the process or look up heat treating aircraft grade alloy on the net, there is a lot too it.
Happy building guys, lets build them safe and strong as the designers intended.
Nick..
