Ready to start applying power to my system, obviously there won't be antennas attached to the gizmos (comm radio, ADSB, transponder, GPS). Should I leave them unplugged/off the main bus, a freind said it was Ok as long as I don't transmit on the comm radio. Thinking it through, the comm radio would be in receive only as long as I don't transmit, but unless I leave them unplugged I have no control over the ADSB, transponder, & GPS, soooo....
If I have to leave them unpowered, how do you test to make sure they're working ok until you have an antenna? Do you make a temporary antenna plane to mount them on?
TIA
TIA
