RVG8tor
I have used Sika to glue on the canopy, I drilled about 7 holes to use clecoes to hold the canopy while fitting. The clecos allowed me to get the canopy back in the same position each time after removing for trimming. The canopy is glued and I like the fit, but in fitting the skirt I must have been a little rough putting the cleco in an out of this hole. I now have what looks like a chip on the inside of the Plexiglas (glued side), I plan to Sika the upper edge of the skirt but have been using the 7 holes in the fitting of the skirt. Not sure what to do about this chip area, I can try to drill it out to a larger size but then I will not be able to debur the hole. It will not get a rivet so it should only have the stress of the heating and cooling and the Sika will give during that.
So any ideas, drill out, or just leave and keep an eye on it. Inject epoxy in there to fill the void around the chip like they do with windshields? Silly that I go to the trouble to glue the canopy then make my own stress point!
Thanks for any input.
In the picture I have a flashlight on the are so it stands out better. The hole is 3/32
