D dwranda Well Known Member May 18, 2020 #1 This is probably a dumb question, but what is this hole in the baffle for? Of all the aircraft pics I've looked at I have never seen this hole being used for anything.
rocketman1988 Been around for awhile... Sponsor May 18, 2020 #2 plug wrench It lines up with the spark plug...a socket extension will fit through the hole...
Raymo Well Known Member May 18, 2020 #3 Suggest taping them off with aluminum duct tape between plug changes to help with cooling.
D dwranda Well Known Member May 18, 2020 #4 Ah yes that makes sense. Since I'm using a fiberglass plenum that hole really won't do anything for me i guess.
RV7A Flyer Well Known Member Patron May 18, 2020 #5 Raymo said: Suggest taping them off with aluminum duct tape between plug changes to help with cooling. Click to expand... Or you could use the hardware called out in the plans...AN509-10R10, 2 pcs AN3235-028-24A, MS21042-3.
