I'm finishing the last small touches on my rv6a and I'm greasing the wheel bearings today. I have the Matco wheels and they come with a timkin tapered roller bearing with integrated rubber seal. How can I grease these by hand? The rubber seal is on the larger diameter side of the bearing and this is the side typically used to pack the bearing by hand. Also how do you know when the bearing is full as the seal is in the way so you can't see any flowing out the other side? Confused... (-;
Bill
Bill
