dpansier
Built up this multi function portable power source for aircraft camping, has USB ports to charge and power phones / iPad, GoPro and the ability to be recharged with a small solar panel or ground based battery charger, no aircraft recharging.
I added a patch cable to the aircraft main buss with a 20 amp fuse and an Anderson Power Port plug to back feed into the panel in the event of an inflight Alt / Bat failure.
Lithium LiFePO4 16 AH
Lithium LiFePO4 9 AH
Blue Sea USB Charger, tested very RF clean
Lithium Battery Meter
Strobe light for location purposes.
Plano plastic ammo box
Weight 7.8 lbs
