And it's got really great resolution --what is that 2500 dots per inch? That's blow even the vaunted Chelton resolution away!N941WR said:
Darn that Dynon quality control!Davepar said:One EFIS is for a left bank and the other is for a right bank. Don't know what he's going to do about straight-and-level.
The instrument panel was painted with three coats of Pewter Rust-Oleum Textured, Fine Textured Finish (yes, it is spray paint) found in the aviation section of my local Home Depot. The panel was wet sanded with 600 grit wet/dry sand paper between coats and baked in the oven for two hours at 200 degrees F.
N941WR said:FYI - The "receiver" part of that GPS cost me all of $1.00 and I found it at Wal-Mart. The best part about it is there is no monthly Sat fee associated with it.
As for the "mold", it can't be I have a dehumidifier running in my basement aircraft factory. However, if you look closely at that sectional, there is some ocean in the lower right hand corner. You do know what an ocean is don't you?![]()
