Low n Slow
The ventilation of the flying -4 we bought may have been ok for the Seattle area where it was built, but the cockpit was like an oven during the summer in the southwest.
We added a NACA duct which helped, but I also started looking into portable air conditioning systems. We thought the prices of the portables pretty high so my partner was considering building one when I found this cooling system on the web.
It includes a 22 quart cooler filled with ice and a small amount of water that’s pumped thru baffles in a rubber bladder normally worn like a poncho. The pump pulls a little over 3 amps on startup then runs continuously at about 2 amps. I mounted the vest by draping it over a 7/8 diameter PVC pipe so the circulation wouldn’t be pinched off when leaning against it, then tie-wrapped the pipe to the roll bar. To keep it out of the sun I added a thin seat cover installed with a smaller diameter tube also attached to the PVC pipe with tie wraps.
I usually fill the cooler with ice packs and a few frozen bottles of water so the water level doesn’t increase as they melt. The seatback cools a relatively large surface area and really helps both on the ground or while flying in warm air at lower elevations. The system was $144 shipped across the country. I found another company that makes a unit specifically made for a seatback, but they wanted $400.
http://www.jenkinscomfort.com/Serpentine Bladder.htm
He also sells on eBay;
![2rrazjo.jpg](/community/proxy.php?image=http%3A%2F%2Fi34.tinypic.com%2F2rrazjo.jpg&hash=f7e9f03f643f38d1b6db2c5a7194dc33)
![2u93d3d.jpg](/community/proxy.php?image=http%3A%2F%2Fi33.tinypic.com%2F2u93d3d.jpg&hash=d7f0b306bf77ef45634cc088bee6a6b3)
![111kzls.jpg](/community/proxy.php?image=http%3A%2F%2Fi37.tinypic.com%2F111kzls.jpg&hash=f5ad5b5b65e3ccbc04652a4a88674b41)
![10wjup2.jpg](/community/proxy.php?image=http%3A%2F%2Fi34.tinypic.com%2F10wjup2.jpg&hash=64df32084df0e213ae2e895b9a692564)
![2zoz0wg.jpg](/community/proxy.php?image=http%3A%2F%2Fi35.tinypic.com%2F2zoz0wg.jpg&hash=1e5c41ecdf500a79a7c941abfbebd095)
![2lad82q.jpg](/community/proxy.php?image=http%3A%2F%2Fi36.tinypic.com%2F2lad82q.jpg&hash=1df598a0608d9f4e53d6772c3ca4b9a2)
